Gears vs MPG please help!
i have a 08 silverado 4.8 reg cab long box 4x4 with 3:42 gears in it i put a magnaflow muffler a K&N drop in filter and a diablosport tuner and running factory 265/70R17 tires still only pulling 13-14 mpg no matter what i do. im usually city driving with 8 mile high way ride to work. Im wondering if swapping to a 3:73 would help my mileage out since it seems like i have to always give it so much throttle just to enter the highway/merge/take off at lights. What do you guys think?
Kinda what i thought to since the thing is a complete slug on the road. It ran really good in the dunes the other weekend in 4low but you could still tell the gear ratio was really hurting it.
regearing costs way to much to go from 3.42's to only 3.73's. the benefit doesn't outweigh the cost at all. Especially since yours is 4x4, you'd have to do the front and rear. If you were going to regear, i'd say at the very least step up to 4.10's
Well higher numerical gears (4.10 being high than 3.73) is going to make you engine RPM go up. Generally when engine RPM goes up so does fuel consumption. usually people go to a numerical lower (although often refered to as a "taller" gear).
And about the cost, relatively it is still costly to do a gear swap. Eventhough you may not have to pay for labor cause of your uncles shop, the cost of new gears front/rear and both install kits will run you between 400 and 600 bucks.
Man Motor club
1 Post
It will take quite a while to recoup your cost on fuel savings if that is your only motivation for the swap. If you are looking for more torque and a more drivable setup with your gear swap, I would most certainly swap to 4.10s and skip 3.73s altogether. Don't fear the gear.
