engine rebuild No OIL Pressure
#21
Whats the deal with it backfiring? I bet money if you could get it to run for 5 seconds or more oil pressure would come up. You could even unplug fuel injectors and crank on it for awhile, 15 seconds of cranking had the gauge moving on this suburban even with the spark plugs still in it.
#22
richey (03-24-2023)
#24
Mod with training wheels
The backfiring was throwing me off... What oil pump is it? Some are more prone than others to having sticky relief valves. Not sure what effect pressurizing the back side of that valve would have... But sometimes the solution is just to let it run longer. I've seen them take a cringeworthy amount of time to build pressure on a first start.
#25
#27
I am still in need of some help especially from you guys who know how the oiling system works. So I spoke with the engine builder and he said to prime the system the same way as the video I posted. Pump oil into the galley plug at the left front of the engine. I have done at least 15 quarts this way and never get even a 1 pound of pressure from either gauge. I am using an actual tank and compressed air made for this job now.
I then seen a lot of guys prime by removing the oil filter connecting a hose to where the filter threads on and pump oil in this way. I instantly got oil pressure on both gauges up to 30 psi. WTF does that mean but I still get no oil pressure when cranking and can not see any oil coming from the valves with the cover off.
Does getting 0 psi from one direction and 30 psi from another mean anything? Just a reminder engine was rebuilt a DOD kit installed I've already confirmed the barbell is present and the pick up tube and o ring are correct.
richey (03-24-2023)
#28
#29
Do you know if the barbell has it's oring?
Oil flows like this in an ls wet sump system:
pickup, through the pump, to the filter, past the restrictor, and into the feed lines.
If the restrictor is missing the oil gets pumped out the back of the block behind the cover.
