engine rebuild No OIL Pressure
I had my engine rebuilt professionally but I am getting no oil pressure. I have hooked up a mechanical gauge to make sure. I also pre oiled the engine and was able to build pressure at the factory gauge so I doubt its a gauge issue. I also pulled the drain plug to check if the pickup tube is there and I'm fairly certain I can see it. Engine is 5.3 had it bored to 5.7 dod delete kit installed triple 12 cam rods pistons stock crank.
I have started it twice ran for a second or 2 then died. Since the attempted starts I have cranked it about 6 times after the mechanical gauge install but no pressure. engine has sat for about a year after rebuild do ls engines have trouble priming?
What should I start with to figure this out?
Yes that can be plugged after doi g a dod/afm delete. It is a relief valve from what ive found that limits oil pressure to around 55psi.
Is your oil filter full? That right there will take a few seconds to fill.
Did you plug the afm oil ports or use the correct valley cover with the orings to seal the ports?
Isnt there some barbell type deal that is common to be forgotten to be reinstalled that kills oil pressure?
100% Redneck
The most common low oil pressure issues are the pickup o-ring, missing barbell (posted above) and using an old cam thrust plate. If the old thrust plates orange gasket is squished flat oil pressure dumps from the lifter oil galleys into the front cover. This is usually a low pressure issue instead of a zero pressure issue. Check the oil filter like posted above and maybe pull a valve cover to see if the oil has actually made it to the top.
100% Redneck
The rear cover has to be removed to access the barbell. On my GenIII there is a oil plug on the drivers side block above the oil filter. You should be able to see the plastic barbell through this removed plug... but not install or remove the barbell.
I'll look for the oil plug and see what I can see. The pickup tube I removed had a green o ring. The new one I put in had a red o ring. It was a lot of work pulling the oil pan ended up removing the front diff and some other crap. Should have just pulled the engine.
