Engine Light at +100MPH
Old Feb 17, 2011 | 11:45 PM
gs7793's Avatar
Originally Posted by USMC45
I have a 2011 RCSB 5.3 6L80E 3.42
thats a pretty freakin cool setup (minus the 3.42's)
Old Feb 18, 2011 | 12:19 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
^^^Add a TVS2300 and let it eat!!
Old Feb 18, 2011 | 12:39 AM
Jordan927's Avatar
3.42 is perfect. I have em in my truck.
1,2, and 3 are lower gears, and like 1 and 2 in a 4L60E with 4.10, or larger...than 4,5, and 6 is like 3 and 4 on the 60 running 3.23's
Actually 3.42 rear and 1st in the 6L80 are like running the 60 with a 4.56 rear
1st is 4.03 ...3.42X4.03 is 13.78
60E 1st is 3.06...with a 4.56 rear your looking at 13.95
It gets you up and going in a hurry, than leans out so you can cruse at a higher speed with low RPM.
I also spin the tires changing into 2nd and 3rd with my 6L80E and 3.42 rear. I change to 3rd at 6K rpm and 110 or 120km/h..it spins enough to set off the T/C light
Old Feb 18, 2011 | 01:03 AM
silverado1ss89's Avatar
Originally Posted by AKlowriderZ71
A RCSB with tall 3.42 gears should be okay at those speeds. I have had my ECSB (longer alum shaft) to 130 mph with 3.73 gears when I felt a "change". I promptly slowed down.
I had hit 130-135 a few times like about 10 times actually I have 3:73 275/55/20 tire. I haven't broken my shaft yet ( knock on wood):nunchuk1:
Old Feb 18, 2011 | 01:29 AM
Daryn's Avatar
Formerly darynC-10/23/10
a one pieve steel dshaft will hold up alot better . ive had my truck up to 14X mph with the stock one and i had 3.73 gears
Old Feb 18, 2011 | 07:47 AM
Rhino79's Avatar
9 Second Club
Ive been 136 with my CC and 3.23's and 29" tires. I won't even push it with the 4.10's though. Back to the OP, go to autozone and have the codes pulled.
Old Feb 18, 2011 | 08:15 AM
fortplainman's Avatar
after my BBP tune, i had my rig up to 136-138. i figured the stock tires would of failed before the driveshaft. never been that fast again lol(and not because i got it lifted 2 months later)
Old Feb 18, 2011 | 09:32 AM
Parke10's Avatar
Maybe someone can confirm, but isnt blinking normally a misfire? maybe its misfiring under load for some reason.
Old Feb 18, 2011 | 11:15 PM
USMC45's Avatar
That is what it says in the manual, a misfire. And like I said my 08 had no problem at 125 so I was just wondering if that was something new in the newer 2011 model. I'm gonna get it checked in the morning though so hopefully it gets taken care of.
Old Feb 18, 2011 | 11:18 PM
USMC45's Avatar
I plan on putting a Turbo on it in the near future so those 3.42's should come in handy.
