Drop Shackle with Support Airbags
Do you need to make any modifications to the airbag support brackets so that they will work properly with a 2" drop shackle? What about with the block removed as well? I have towed with the 2" shackle and it was bottomed out on the shocks (I installed shorter bumpstops).
Thanks for the help, this seems to be the best forum for these trucks! |
Someone has to have dealt with this!
Ok here are my results AirLift kit installed, before you air up the bag it looks like it's a no go. Once aired up there is not a single problem!
If you mount the top support at the right height it will work.
(Post 4959457)
