Disc Baking Plate
Mar 18, 2024 | 12:36 PM
Looking into converting my NNBS Sierra rear drums to discs. Thinking about going the route of dual calipers from a 01-04 NBS suv. I ran across this part number from gmpartsdirect - 89026786. Does anyone know if that’s the correct backing/anchor plate that I need?
Reply 0
Mar 21, 2024 | 10:07 PM
This should answer some questions: https://www.performancetrucks.net/fo...s-12-a-559523/
Reply 0
Aug 11, 2024 | 06:46 AM
When doing this, there are two types and I can't remember if it makes a difference. The smooth caliper found on 2wd SUVs with a 1.125" thick rotor and the ribbed caliper found on the 4wd variants with a .875" thick rotor. Highly suggest going to a salvage yard and either grabbing the whole rear axle and returning it with your brake parts or pulling the backing plates, calipers, rotors, and parking brake cables and calling it a day. That will guarantee you get all the parts including the hardware which may not be easily purchased such as parking brake cable retainers and such.
Reply 0
