Brake rotors are bad rusty groved which ones to get would like slotted/ drilled
My rotors are bad and brakes pads almost gone,When u guys upgrade what are u guys buying.Want something better than stock but reasonable.ARE the POWERSLOTS any good,I see sum guys are running HAWK PADS also.SHOULD I UPGRADE TO A BIGGER ROTOR?Read u need sum bracket or something cant find thread CAN SOMEONE POINT ME IN RIGHT DIRECTION...What are a few recomendations THANKS GUYS like peoples input...
IF i put little bigger rotors what do i need to do thot i read before theres a bracket u buy..
Summit has a nice ssbc rebranded upgrade. I would use a good pad like hawks and make sure none of your pistons are sticking in your calipers.
Dont run drilled, the tend to spider after a while of extreme abuse.
Like what u guys have to say i like peoples input and experiences.ANY one running bigger discs up front.
If I had the money, I would do the wilwood big brake upgrade front and rear. But I don't, so I can't.
i would to but not that rich lol wana go w maybe powerslots if there any good w gd brake pads
Which rotors are better powerslot or powerstop?Can a guy run bigger rotor without diff calipers...
