brake light on and abs light is on after track day
ok so i ran my 07 this past weekend ( managed a 13.000) anyway im coming home and my abs light comes on as usual when i run the slicks in the back with the 22's up front, well my brake light comes on too and its making the chime sound too. and now when i crank up and get goin for about 5 miles the brake light and abs light will come on and start chimin.
its ben doing it every time i get in my truck and go somewhere... anyone have any ideas? i recently changed my front rotors and pads. i still havent touched the rear(drum) |
do you tune for the tires at the track?
no i have some 22's that have the tire sensors in , and stock 16'' for the back with drag radials,
Have you put the 22's back on the rear?
yes i have, i really cant think of anything other than the rear brakes need to be changed... eh????
well first the shorter diameter tire in the rear will throw that code.
also if it's still doing it after you put the regular tires on and you did say you just changed the front brakes, i'd have to go with the speed sensors are dirty up front. mine does it all the time. |
Im having an ABS problem as well! just got my 08 scsb from the local shop and did a burnout at home and it threw that code??? trucks brand new with 7k on it so what could it be??
its most likely throwing it because the front and rear tires are spinning at different speeds, ie ;different size wheels or a burnout, one time in the rain my tires spun a little on take off and my abs and brake lights flashed but turned off right away.
