anyone relearn the tire positions yet??
Old Aug 30, 2007 | 12:30 PM
circusboy's Avatar
Default anyone relearn the tire positions yet??
I rotated the tires a while back. Now that I have the DIC buttons, I can see the tire pressure for each tire. Except the truck didn't relearn the location of the sensors. The computer failed the relearn and now the damm tire pressure warning light stays on. I got out the manual and read how to reset the system, but it does not let me finish. It's being a PIA. Any one else have this problem?
What did you do to fix it?
Old Aug 30, 2007 | 01:00 PM
Blown02Sierra's Avatar
If I remember correctly: Once you start the sequence you deflate the tires around the truck going front left, back left, back right, front right and stopping as the truck honks at each tire.
Old Aug 30, 2007 | 01:35 PM
Tim 98z's Avatar
I had to do this when I put the new wheels on.
It will turn on the headlight in relation to the tire you need to do next.... mine was FL, FR, RR, LR
Let the air out of tire with the light on till the horn honks at you. Then air it back up. Move to the next....If one is off after your completed with all 4 it will tell you what tire needs adjusting.
Old Aug 30, 2007 | 07:10 PM
dirt track racer 81's Avatar
you first have to open the door, set in the truck and close the door, turn the key to the on position grab your nuts for 7.8 seconds, then put the vehicle in neutral, pess the parking brake, turn the radio on, jump out of the truck, run around the truck 2 times acting like a monkey and grabbings your nuts and then come back to the truck, hop in and turn the key off, then put it in park..
anyways the vehicles that have those are junk..i replaced 4-8 of those a day for the dealership here in town
smokeshow
Aug 23, 2015 08:23 PM
JFortner5
Aug 20, 2015 08:26 PM
KOOKS Headers
Jul 27, 2015 01:43 PM
atxlt
Jul 20, 2015 11:06 PM
