Any line locks with ABS
Thanks for the info. I just need to decide which method works best for me. Lock the front or prevent pressure from reaching the back. Sounds like the rear would be the way to go. If I decided to go with the front, would this deteriorate the ABS in the long run?
13chevy (11-19-2017)
Line lock
I put a line lock in my 2000 S-10 in 2001
on the front brakes, works great. never had
a prob with the ABS to this day. going to put
one in my 2010 Colly in the spring. I spliced
into the line coming out of the MC going to the ABS.
13chevy (11-26-2017)
Little help
On a 2013. Which line on the master cylinder send pressure to the front wheels. I have seen info on older models which it switches back and forth, depending on year, but can't find any block diagrams for a 2013
I have mine hooked up to the front line, wired up. I can hear the solenoid activate and I get the light for power sent to the solenoid. It doesn't seem to be working properly. I'm not getting any ABS lights so I don't believe the ABS to be causing the issue.
Pretty sure I'm on the wrong line but want confirmation before I start cutting lines again. Thanks for the help.
I installed it before the ABS and I don't know what does what. Don't believe what I have now is working correctly. Feels like it's working against the brakes. Guess I'll just have to rerun the lines, but I'll give it a week or two to see if anyone else has any input.
