Acceleration delay - 2009 5.3 6-Speed
#21
if its 87% then you have it give it 87% throttle before you get PE. Do you really want to have to almost go WOT to get PE, I hope not.
What I do is look at the logs and see where I do most of my driving, typically around 30% throttle, so then I make sure the enable TPS is above that. I also dont command PE until a higher MAP, unlike above where he basically controls everything through the TPS table.
#22
Your explanation makes perfect sense of course.
I said 87 was stock. I have no intentions of leaving it there
#23
The 87 is stock, just sometimes when I look at what guys are tuning I wonder why they used 39 instead of 40 or 48 instead of 50 etc...wasn't sure if that's just where you felt it was really good or there was a specific reason behind that number.
HPTuners is awesome, bit overwhelming though as a noob so sorry for the stupid questions. Learning though, its pretty neat.
Thanks!
Thanks!
Ton's of great info on the HPTuners boards...
#24
Guy's I've got the same **** going on with my truck,it's a 07 ext cab 5.3,my tuner who use to tune my corvettes said it's because I don't have the tpms sensors in the wheels.I bought the truck as a repo and all I no about it is that it has to have some kind of programmer and servo in it because it will nail second gear and run 9.70's in the 1/8,with no headers,cai,or nothing.I'm going to get my tuner to check the tune in it soon just to see if we can find out whats done to it.I hope someone kind find out what the deal is because mine does it at least a couple of times a day.THANKS!
#25
mine does the same thing its really annoying I feel it more when i manually down shift to run and when i hit the gas it just seems like the TB lags or just cant keep up with my throttle input......and my truck is tuned ill talk to my buddy File who tuned my truck and see what he says about this.......one question tho would switching out to say a LS2 TB fix this ? The only reason I ask is because my buddys 6.0 GTO has no lag what so ever just thinking that maybe the gear ratio on our trucks TB is higher then on a LS2 car TB and the little motor that opens and closes the butterfly just isnt as quick. Idk if im making any sense but hopfully someone will get what im saying........
#26
i know what you mean and i'm interested to see if that fixes it aswell... the only thing i ask though was the gto an m6 or auto? because the m6 has not lag at all but i noticed some serious lag in the auto's
#28
man, i have only had my truck for 100 miles and i felt that right away. a tune should clean it up. i am not gonna tune this truck until about 10,000 miles. maybe a lil sooner, cant wait to open up the beast.
#29
#30
Im writing all this stuff down so that when I go retune the truck I make sure my tuner fixes this problem.
btw.....dubai_222s truck is sick.....some people are going to be surprised when they try to race you.
