4l60e to 4l80e
thank you madman26 on the flex plate i have one of those custom one from circle d i got back a couple of years ago its that orange one will it work or will i steel need a new one?
I kept my original 5.3 flexplate, just made sure my new circle D converter had the correct bolt spacing, didn't use a harness mechanic knew which wire to repin to ensure it read properly.
so your saying i dont need a harness and all i need is a mount and a 4l80e with a tune
If it was 4wd different input shaft I forget? I may be doing it if I buy a different truck. Thanks Jessie!
Correct if your ok with having your harness repinned and tech knows how to do it.. I'm sure there's post on what pin needs to be moved and vss plug. My mechanic knew this as I had a Nelson Performance harness but wasn't used.
Thank you fellas im just tired of changing this damn transmission out for 10 years on and off i love the truck and the motor but i cant ever get a transmission to hold up good ive spent thousands and im sick of it going out after a couple months.
BLOWNONE
03-01-2011 10:16 AM
moregrip
01-13-2007 04:27 AM
