11' CC 4x4 want to drop
We do wheel alignments at the shop so alignment is no problem. BUT, do they need alignment to the extent that once everything is correct there is no more adjustment left in the event it needs alignments in the future or is there still room for lots of adjustment in the future if necessary?
The fact that it needs a lot of alignment doesn't necessarily mean much of anything it is in what department all of the adjustment needs to occur and how much lee way you have to do alignments in the future that will tell you where you are actually at when it is all said and done.
I would go with a 2/4-5 with Mcg coil relocators and a flip and lift hanger. Ive done many many Mcg spindles and do know what your talking about on the ball joint but it has never caused a problem for me or anyone ive heard of. A 2/4 is noticeable on these trucks, its sporty but not slammed.
Could be the mcg spindles I installed were defective or the design has changed since.
The top ball joints didn't seat in the hole in the top of the spindle the way the oe ones do,
like there was not enough taper cut in the spindle.
I recall at the time a few other people reporting similar fit issues.
On the same truck[2008] the upper ball joints were trash in 10k miles and had to be replaced. That may not be related to the spindles.
gaps
10-15-2015 02:53 PM
