'08 on 3/6 DJM
Hey JB, one of those was probably my post on GMFS, I go by miamigrant over there. I hate that user name, I don't even live in miami anymore but it's too old to change i guess. To be fair to DJM, I haven't actually gotten my hands dirty to see what the problem is yet. Somebody may have posted the thought of possibly reaming the upper ball joint taper too much on one side or I just dreamed it up but that might be a possibility. I just need to get off my large rear and go check!
I understand your not sure what the problem is, but with his having the same issue it makes me wonder. I know mine sits even. If your truck sits even stock, it should sit even lowered/lifted with the NNBS.
Shupe, the lean is definitely coming from the driver front. Something was done during the alignment because it measured perfect right after I finished. I've posted on another forum and everybody is scratching their heads, I just have not called DJM yet. Can you post pics of your truck? And if you ever make it out to Pea Ridge stop in! I'll be around all weekend. You're not related to any Shupe from Green Ridge, Mo are you?
Good luck on the correction of the lean.
DJM arms don't cause chevy lean, for whatever reason on my truck with the arms it was bad...now the other kit fixed the problem. I later discovered bad bushings and destroyed ball joints, no doubt contributing...
