What Sensor?
Old Mar 7, 2011 | 02:24 PM
Default What Sensor?
Hey Guys,
I got an ABS light on and the truck isnt throwing any codes, i just had my right rotor replaced about a month ago. Is there anyway of telling which front sensor it may be, i have searched and found that the grounds on these trucks suck so i could look at that also. If the sensor is the problem should i just go with an Oriellys or do we have and vendors that supply that i could possibly support?
Thanks for the help
I know my sig may be out of date but truck is a 2002 5.3 2wd no real mods to suspension
Old Mar 7, 2011 | 02:37 PM
00ChevyScott's Avatar
Wearin' da big hat
You'll need to have the ABS code read, which requires a different tool. I work for O'reillys and our new code scanners have the ability to pull ABS codes, but I'd suspect since work was done on the front right rotor, that it could be your problem. Although both the ABS sensor and ABS ring are on the back side of the hub assembly. It might just be dirty and need cleaning, or you could have a faulty sensor. In my experience, it's usually best to replace the whole hub as they come with a new ABS sensor installed, and aren't all that much more expensive. After all, you'll need to replace your front hubs at some point soon anyways assuming you have a lot of miles (9 year old truck).
Old Mar 7, 2011 | 03:39 PM
Ok so just to get this straight, a new hub does come with a new sensor? I had a shop replace the whole hub for me and im sure i might have just got screwed if it does come with one?
Old Mar 8, 2011 | 08:45 AM
moes04silverado's Avatar
the hub assemblies in these trucks have always had issues. The aftermarket replacements have gotten a lot better over the past few years. My 04 ive replaced both front hubs... and my 02 needs one on the drivers side the ABS goes off everytime i apply the brake!
Old Mar 8, 2011 | 09:33 AM
fastnblu's Avatar
Originally Posted by moes04silverado
the hub assemblies in these trucks have always had issues. ... My 04 ive replaced both front hubs... and my 02 needs one on the drivers side the ABS goes off everytime i apply the brake!
If this is the wheel speed sensor, isn't that the same as that on the hub? If so, my bros. '02 Silvy had both go bad. Now 1 of em or both are shot again. He lightly grazed another vehicles rear bumper. The brake pedal made this pulsating funny sound, then when to floor & no brakes.
On HPT over the last yr., I have a code for both front sensors, but not to the degree some have had issues.
Do both OEM hubs as well as aftermkt. replacements include sensor when u buy the hub? I was told the OEM units will last longer, but it's a lot more scratch.
Old Mar 8, 2011 | 10:02 AM
is it safe to clean these sensors with MAF cleaner?
Old Apr 9, 2011 | 03:04 PM
spaulsen's Avatar
any vendors here offer these hubs? also, sensors included?
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Oct 3, 2015 03:59 PM
Wrecker 426
Sep 30, 2015 09:39 PM
WICK3DxGATA
Sep 24, 2015 06:56 PM
