What Helper Bags Will Work with Belltech C-Notch? 03 RCSB
Hey everybody,
I have an 03 Sierra rcsb with a belltech 2/4 drop and a belltech c-notch. I don't ever bottom out on the frame with the c-notch, but the tires will rub the fenders if I put any kind of load on the truck whatsoever now. I need some helper bags. Anybody got a link to a kit that will work with the c-notch? The truck used to have bags on it, but the bracket was mounted in the area where the c-notch is now.
Any help will be appreciated.
I just recently put airlift slamair kit on my ss, its not really lowered much but came out alright. I only took one pic, id imagine the way i have them (on rear side of the axle) would be in the way of your notch. You might be able to put them on the front side of the axle instead. If not might need something custom upper bracket wise or i think i rem mcgaughys had a kit might check out, might of been for a flipkit..
I may end up having to just get something fabbed up, but I figured one of the main suspension sources would have something designed already for people with a notch. I have found kits designed for people with flip kits and a notch, but not without a flip kit.
Here's a couple of pictures to show the wheels and tires that are on the truck
I have a suspicion you are going to have to go with a custom fabbed setup. You could go with the SlaimAir kit like skolman posted above and modify the upper mount to align with the c-notch bolts. Or use the Belltech upper mount and modify the lower bag mount from the slamair kit to align the bag with the Belltech upper. I feel the bag on teh Belltech flip kit set would be too tall even if you modified the lower bracket to work.
A third option is to go completely custom with the upper and lower mounts then select the proper length bag to give the right amount of extension, compression and lift. Firestone, AirLift, Goodyear/Stemco and Torque all make air springs in many sizes for semi cabs that would fit the bill.
Maybe hit up Atomic Fab to see if there is something he can draw up for you since he is in your neck of the woods.
