-   GMT 800 & Older GM General Discussion (https://www.performancetrucks.net/forums/gmt-800-older-gm-general-discussion-130/)
-   -   what fuel system? (https://www.performancetrucks.net/forums/gmt-800-older-gm-general-discussion-130/what-fuel-system-419380/)
4.8 truckin Jun 9, 2008 12:56 AM
what fuel system?
Hey guys i have been doing some reading on the different fuel setups our trucks have return and retureless how do i find out wich one i have?:confused: My truck is a 07 silverado classic with the 4.8. what fuel system are guys using on the 07's for mods like a turbo setup.
2005 Silverado Jun 9, 2008 12:57 AM
99-02 where return, and 03+ are returnless, and most of the time its bigger pump and injectors.
Dustin
4.8 truckin Jun 9, 2008 01:28 AM
A bigger pump and injectors is what i need then what fuel pump should i go with alot of people are using the walbro 255lph pump in the tank will this work or do i need something differnt? And for the injectors will the 8.1 44lbs(i think) work with the fi or are they to small.
thunder550 Jun 9, 2008 01:30 AM
255 in tank pump and 8.1L injectors will do well up to a certain point. How much boost are you planning on putting through that 4.8?
4.8 truckin Jun 9, 2008 01:33 AM
Its just going to be my dd so i think about 6-8psi (low) 10-12psi (hi)
thunder550 Jun 9, 2008 01:36 AM
That should work...you'll have to keep an eye on your fuel pressure and AFR. I think 10-12 psi might be close to the limits of that setup but it will probably work.
4.8 truckin Jun 9, 2008 01:40 AM
Cool thanks for the help man it should only see the higher boost when racing or messing with friends. :D
4.8 truckin Jun 9, 2008 10:57 PM
Would i need a fuel pressure regulator with the returnless system. If so do i have to run a return line back to the tank.
thunder550 Jun 9, 2008 11:42 PM
You're talking now about converting to a return style system. If you keep your erturnless system, you don't need an FPR or a return line. If you convert to a return style system, you will need a FPR and a return line.
4.8 truckin Jun 10, 2008 11:25 PM
Ok i can keep the returnless system i have right now put the intank pump in and the 8.1 injectors. with the turbo system and it will work just fine. that would be very good:D because it saves a bunch of time.
What controlls the fuel pressure?:confused: thanks
