I personally preferr the E85 setup. This will allow you to run E85 with boost if you want to and still have the pcm pick that up. The stock pump on the E85 vehicles commonly are big enough to flow all of the fuel you're going to need for a boosted 5.3L. A TVS1900 on that engine would be bad ass. As for using the stock injectors under boost, even the 38's on the E85 engine aren't really big enough for much boost on a good running 5.3L and a returnless fuel system. On an E85 truck I'd go to 60's or bigger.
Originally Posted by explorer5.0
(Post 3831332)
E85 requires more fuel flow. Those 38(?) lb injectors that the flex fuel trucks have will support his power goals with gasoline; but to make that same power on E85, he will likely need 50-60lb injectors.
what is the size of the gas injectors and E85 injectors for comparison? Isnt the entire fuel system SS on the E85 or is it the same on both? |
Swap?
My Tahoe is a flex fuel but found a low mileage LY5 can I use the LY5 and just put all my components and wiring harness on this engine and it work
thanks |
