Are there aftermarket motor mounts available? Also tune question...
Old 10-23-2018, 08:13 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Originally Posted by camar0corey
So the brake error message is likely coming from the gear and different tire size, versus going from drums to discs?
What kind of blowers are going used in that price range? Roots? Centrifugal? How much beefing up of the 4L60E would be needed in that case?
So maybe sell the rockers to fund the tune haha and then just be happy.
Any input from those running solid motor mounts? $150 versus $350 for the polys is tempting but it is a driver...
The break system has no idea if you have drums or disk.
the gear ratio and tire size are programmed and when it detects error above the allowable limits it sets a code.
Various things use those values for calculations including the ABS system, transmission and so on.
camar0corey (10-24-2018)
Old 10-24-2018, 07:10 AM
camar0corey's Avatar
Good to know then, I'll cross my fingers that goes away once those values are changed.
I think this thread is getting wayyyy off topic, even I'm guilty right now. I'm not trying to make a stupid fast truck, but I want it to have more get up and go then it currently has. Here I am though inquiring which style blowers are going used for $2500 and looking at beefing up the trans...
I think maybe I'll just get a tune for it after I do the motor mounts. The rockers can sit on a shelf, and I'll look for a 09+ 5.3/6l80e combo down the road... I'm really trying to keep the truck fairly simple, I don't think I want to go the forced induction route. I've currently got some Fbody projects, one I have the D1SC for (94 Z28, the 95 convertible "parts car" also came with a Golen 383, along with the procharger) and an 87 IROC that will get a chinese turbo after the LT1 swap (car already has a t56 swap, and a boost ready motor is coming out of my 94 Z28). So yeah not looking to go nuts with the truck haha.
Old 10-24-2018, 09:08 AM
97_ek's Avatar
I'll second the recommendation for the Atomic Fab and Performance poly motor mounts. They are well-built, and they fell right into place when I swapped my 6.0 in recently.
Old 10-24-2018, 11:16 AM
arthursc2's Avatar
Received 1,433 Likes on 1,061 Posts
Centrifugal blowers are generally the cheapest, they are also the easiest on the drivetrain. They make an NA power curve, just a lot more of it. Ive made 477 through my 60e with a tune and shift kit. Its not going to last much longer, and I never expected it to, but so far it still moves the truck.
Roots blowers provide the best off idle torque, nice to get a truck/trailer moving but also the hardest on the trans
Turbos make the best ultimate power. Large enough turbo will act NA during cruise and off idle situations, but when she lights; hang on.
Old 10-24-2018, 04:23 PM
I have a gauge for that
Atomic's Avatar
I can help you with both motor mounts and a tune as mentioned
Go with a blower for more power, and you can always pulley it down and use it on a bigger engine later. I ran a tvs1900 on a 408 for a time, did great.
Old 10-24-2018, 06:06 PM
arthursc2's Avatar
until the bearings took a ****.
I am a huge fan of blowers, but anything is better than nothing
Old 10-25-2018, 03:36 PM
So... still torn between poly or solid. I've read in a few places where people with solid said they didn't notice any more vibration. Input?
Yeah I'm just thinking no blower. Will probably just go 5.3/6l80 down the road if I can find a pullout with motor, pcm, wire harness and trans together. I'm thinking I'll just be patient. I read somewhere it was changed from 24x to 58x when they went to the 6l80e over the 4l60e???
Old 10-25-2018, 04:06 PM
arthursc2's Avatar
Poly. Not worth risking breaking the block
58x switch happened in 07 for trucks. Earlier for LS2 GTOs
Old 10-25-2018, 04:24 PM
Atomic's Avatar
Both will be very strong, but the polys will be more forgiving. In regards to vibration, as long as the engine is healthy and there are no issues extra vibration will be minimum. Most report the only time they can tell is at a cold start idle, the rest of the time no difference. If you have an engine issue (misfire, out of balance, etc.) then yes it will be more apparently because the poly or solids are not near as forgiving as the stock mounts.
The stock mounts are fluid filled mainly to deal with the DOD activation so the passengers dont notice it as much.
Old 10-26-2018, 08:32 PM
Is this a concern for an iron block???
Quick Reply: Are there aftermarket motor mounts available? Also tune question...
