Supercharger advice
#22
So doing some digging I see I will have to buy a new transmission crossmember, a new torque converter, a set of transmission lines, a modified or swap harness, and a modified driveshaft with a larger yoke and crossover U-joint to get the 80 swapped in. This is getting way up there in cost for 150 hp with a $1800 to $2300 performance tranny alone. Will be looking into beefing up the 60 or leaving the truck as is.
#23
I can buy a built 60e for way less than a 80e from a reputable builder. Who here has destroyed a well built 60e with boost for street use? Plus I'd be happy with 4-500, not looking for 1000hp.
#24
13 Second Truck Club
Well I'm moving on up to 80e this spring My n/a cammed 5.3 put strain on the 3-4 clutch packs (had freshened up before boost) had to upgrade some parts inside to handle more torque (+1k in extras, plus freshen up) not including the single disk converter- now I'm at 1700 + the original stage 4 of $2200 and original $450 3200 stall
I picked up a 2005 - 80e $400
Dipstick tube $35
Some wiring to add to pcm - meh had some
Weld a 3x3 piece of angle to cross member drill new slot - 10$
Shift kit with updateds- $150
SS lines with fittings $120
Converter $800
New tune- $35
Driveshaft will work for me but give you a idea I should've went this route long ago
Sorry hard to read the layout won't work right on my phone
#27
Well I'm moving on up to 80e this springMy n/a cammed 5.3 put strain on the 3-4 clutch packs (had freshened up before boost) had to upgrade some parts inside to handle more torque (+1k in extras, plus freshen up) not including the single disk converter- now I'm at 1700 + the original stage 4 of $2200 and original $450 3200 stall2005 - 80e $400Dipstick tube $35Some wiring to add to pcm - meh had someWeld a 3x3 piece of angle to cross member drill new slot - 10$Shift kit with updateds- $150SS lines with fittings $120Converter 800New tune- $35Driveshaft will work for me but give you a idea I should've went this route long agoSorry hard to read the layout won't work right on my phone
I am going to get in touch with the guys at PerfomaBuilt and Finish Line to see what they can do or advise. My thinking is if I'm going to spend $2k I would rather it bolt right up instead of modifying it all to fit. My budget was set for a Magnacharger so I'm good at that point with the cost of the Torqstorm but I just would prefer the ease of un bolting the old and bolting in the new. I just don't see why a well built 60e wouldn't handle the extra 150hp?
Also I have the G80 rear end so I should be good there.
#28
If it's the 10 bolt it's not good for anything. G80 just means it has the factory low-bid locker in it (Eaton Gov-Loc) and it will blow up. The Gov-Loc has a bad reputation (nickname: Gov-Bomb) but honestly even if you didn't have the G80, just a regular 10 bolt, that is a weak link as well once you start building any amount of power.
If you aren't going for significant gains over stock then a "built" 4L60E might make it, might not. It's a gamble, with the factors mostly being how well it gets built and how much power you're making, how you drive it...along with just pure luck, the part that you have no control over.
Richard
Richard
#29
Yah you lost me a bit here.
I would have to do it like this awesome write up by KySilverado. https://www.performancetrucks.net/fo...-4l80e-424904/
