rear disk brake help
hey guys!
my rear brakes was shot so i replaced the pads, rotors & hardware also cleaned and greased the slide pins put it all back together and now the rear brakes are getting hot, smell & even the rotors are blueing a little from the heat. temp gun showed 597 degrees right rear and 460 left rear both fronts was around 200 degrees driving normal for about 5 miles locally
every thing is moving freely its a texas truck so not really any rust on the parts to speak of i used a C clamp to push the caliper pistons back in
any thing to try before i swap calipers? no problems before just pads wore out
FFDP i'll try to bleed them and see if it helps?
Black04 pad move pretty easy every thing is clean nothing feels like its stuck or binding
i need to figure this out today be towing my car to RPM trans tomorrow with this truck (hopefully)
Edit: messed around with it today, calipers was hanging nothing i did would get them to fully release unless i banged on them with a hammer from the back side bleeding didnt do any thing so i replaced both rear, when i bleed them the fluid was black for the first few cracks of the bleeders after the swap and bleeding fluid is much better looking but i think next weekend i might flush the system
thanks
thanks
