Catch Can Recommendation
Looking in to a catch can for my 01 Silverado 6.0 N.A motor. Wanting opinions on what can to purchase and I am also wondering about oil and fuel odors after installing a catch can, I am hearing some comments about strong odors after installing.
For an NA motor, there should be no smells as the catch can will retain it's closed loop function. You also don't need anything fancy or expensive to accomplish this.
https://www.ebay.com/itm/LS-Catch-Ca...item54263fd987
That is what I used paired with a on the fresh air inlet on the PS valve cover.
The hose going from the DS valve cover to the intake needs to be re-routed to the top of the catch can, and the side outlet of the catch can then needs to be routed to the port on the intake where the stock hose was removed.
Here's a post with a similar can to the one I linked to where it's mounted in a silverado.
Where does the check valve go. I got 170K on the clock and need to get a catch can on there. I guess I'm alittle behind LOL
