O2 sensors- bosch or gm
Tranny went down again and while it is out thinking of replacing the o2 sensors. The ones from GM are about $60 a piece and the Bosch are $32 each from Rock Auto. Any difference beside price? Going to do all four.
The truck has ~48K on it and ~40k blown. I'm not throwing any o2 codes but thought it might be good PM while the exhaust is out as I drive the truck like I stole it. |
Get the gm ones. I went through 3 sets of the bosches then switched back to gm
GM! sparkplugs.com is where i got mine!!
GM.... i went through a set of bosch before i swapped back to gm.
another vote for the GM's...you'll likely spend more in the long run with the lower end O2 sensors
Dont waste your money. I have them come through the shop all of the time with triple the miles you have on those and still functioning perfectly. Leave them alone until you have a problem with them.
Originally Posted by 01WS6/tamu
(Post 4722584)
Can one or more start going down, lowering power and gas mileage, without a code? |
GM has 02 fail detection pretty damm sensitive. If the PCM see's a sensor not responding correctly they will set a code fairly quickly. If one is failing to the point of effecting gas mileage and or power you will have a MIL and code.
cool, thanks, just saved me some cash! :D
GM, but I wouldn't replace them just to replace them.
| All times are GMT -5. The time now is 10:12 AM. |
