No room to change plugs cause headers
Old Feb 26, 2012 | 05:38 PM
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by SnakeOiler
Extension and swivel, if needed.
LOL this isn't rocket science.
Old Feb 26, 2012 | 09:02 PM
GREENSIERRA's Avatar
This, once its loose enough just turn it by hand.
Old Feb 26, 2012 | 09:06 PM
dmelvin's Avatar
Are you saying NASA didn't use an extension and swivel to work on their rockets?
Old Feb 26, 2012 | 09:38 PM
SlickSierra's Avatar
you got a lot more room to change plugs with those headers than my obx headers.
Old Feb 26, 2012 | 09:42 PM
black04's Avatar
Damn man I was expecting to see some crazy custom headers or something but it looks like you have plenty of room. Just break the plugs loose and then turn them out with your fingers. Should come out pretty easy after half a turn with the wrench.
Old Feb 27, 2012 | 07:48 AM
Slammed96's Avatar
Truth to that! They're a pain in the *** to do the left rear 2 plugs with.
Old Feb 27, 2012 | 08:26 AM
dmelvin's Avatar
I'm glad we all have to share the OBX header hump headache.
Old Feb 27, 2012 | 10:53 AM
Gordy M's Avatar
My drivers side are a pain to change, I removed the wheel well cove and had a direct shot at the plugs. Too a regular 3/8 plug socket and ground it down a little and gave me more room to extract it after the plug was loose.
Old Feb 27, 2012 | 03:15 PM
40series's Avatar
Default Found some nice 3/8 tubing
I found some 3/8 " tubing which will work nice to get them started, some one also recommended using a open end wrench which sounds good too to breakm an snugem
Originally Posted by aklowriderz71
once you loosen the spark plug with the socket, remove the socket and push a piece of vacuum hose onto the tip of the plug. Then twist it out by hand using the vacuum hose.
Surprised your having that much trouble with the pacesetters on there.
Old Feb 27, 2012 | 03:43 PM
TXSZ66AVLANCHE's Avatar
Remove headers? Change plugs? The install the headers?
