mini delphi to ev6
mini delphi to ev6
Any other suggestion on doing mini delphi to ev6 conversion? I have the connector to convert it but they are very hard to keep in one spot on the fuel rail area. I would be open to smaller connectors and or how to wire it up to where i can get rid of the older bulky connector.
that would be better and cleaner. Do I need to buy new connectors for the ev6 (ls3 injectors) or can i use the ones I got from FCI and just snip the end for mini delphi and solder them.
Eh not really too tied to the harness. I called FIC today as well where i got the connector. They said as long as i keep the wires going to the same side that they are plugged into, that I could go ahead and snip the ends for the mini delphi and wire straight up to the ev6 connector for a cleaner install. Let me know if there are any objections before i snip away.
I just found some heat shrink from local parts store. but little late I already have snipped and soldered driver side connectors. I would have to look to see if it is adhesive. Looks a hell of a lot better but hope it works like it is suppose too.
I bought the weatherpack kit ends and the got an inexpensive set of pliers to crimp the pins and seals on the wires. Its handy as now I can build my own weatherpack connections for everything. So for my EV6 ends I just cut the wires as close to the mini as possible, stripped the wires and put my own ends on. No soldering and easy.
