Lets play name that wheel
3 Attachment(s)
Ok I picked up these wheels earlier this week and I want to know what they are from and if I can get a GMC center cap to replace the bowtie center caps.
Attachment 115776 Here are some quick pictures I took of them on the truck after I got them and put them on, both the truck and wheels are very dirty, and the truck needs a lot more low lol. Also what is the best way to take off the chrome side moulding without damaging it? Attachment 115777 Attachment 115778 |
Maybe Vortec Max wheels?
Easiest way to get the molding off is to leave the truck in the sun so the molding gets hot. Then use fishing line to go behind the molding. You slide it the whole way down the side until it basically falls off. Some residue from the 3m tape will be left behind. Pretty easy to remove with a little elbow grease.
look like gm option wheels
Those would be the GM CK807
Ok thanks! Where can I find GMC center caps?
Contact your local GM dealer and tell them you want the GMC caps for the CK807.
Gm parts direct dot com. Like 137 with shipping. The pn is on the back of the cap. Make sure you order the chrome and not the polished
Cool thanks. I was gonna say thats alot for center caps but after I saw how much each wheel is I guess its worth it since they are genuine gm wheels and not ebay knock offs.
Doesn't centerline make a wheel like that. I thought I read somewhere that gm used that design and just changed it up a little bit.
| All times are GMT -5. The time now is 03:24 PM. |
