inj spacers?
Old Mar 29, 2009 | 07:59 PM
05crew's Avatar
Default inj spacers?
were can i get some inj. spacers? i had some with the old set up but they came with the radix from manga charger. does anyone know were i can get them?
Old Mar 29, 2009 | 08:40 PM
Mangled03gmc's Avatar
Baltimore Whore
Injectors spacers or fuel rail spacers???
Old Mar 29, 2009 | 08:51 PM
05crew's Avatar
i think i just need fuel rail spacers. i have some 65s on the way and need to get some. that is all i need to fit the stock fuel rail right?
Old Mar 29, 2009 | 09:06 PM
Baltimore Whore
Yes should be. You can make a set easy, if you don't find any, get some nylon, do it.. I am sure you will find them on here. Also you might need the plug adapters for the new injects if they are f body stlye
Old Mar 29, 2009 | 09:09 PM
05crew's Avatar
what about small washers
Old Mar 29, 2009 | 09:11 PM
KySilverado's Avatar
I found some aluminum spacers on line and ground them down to the right length about 5/8" IIRC.
Edit: Found the thread.
https://www.performancetrucks.net/fo...ht=60+injector
Old Mar 30, 2009 | 04:43 PM
silver-mod-o's Avatar
Hunt&Fisherator
I picked up 4 1/4" pipe nipples (close nipples) and cut them down to about 5/8 as mentioned and got the longer bolts and they went in just right. painted them black, and besides the bolts being not stock, you cant tell it didnt come like that.
calsdad
Jun 14, 2023 11:07 PM
OHsixLS3
Nov 22, 2015 07:45 PM
bisqikss
Sep 27, 2015 09:40 PM
OHsixLS3
Sep 25, 2015 11:20 AM
