hydroboost problem?
Old Nov 9, 2011 | 05:42 PM
white95birdta's Avatar
Default hydroboost problem?
i searched and couldnt find anything specifically explaining my issue so sorry if this has been covered. just finished swapping in a 6.0 in a new to me 99 2500 with hydroboost. engine now runs but my brake pedal is hard as a rock and i have no power steering. i have a steering cooler but all the lines to that and to the booster unit are not leaking. took off belt and the power steering pulley moves maybe 1/8" back and forth but not much at all. I have an abs light on. wondering if a failed brake booster would cause this issue? Thanks
Old Nov 9, 2011 | 10:10 PM
brent1976's Avatar
11 Second Club
Unhook the line to the booster, and see if it spins then. If it doesn't it's probably the pump.
Old Nov 10, 2011 | 09:25 PM
bad power steering pump.
Old Nov 10, 2011 | 10:16 PM
Atomic's Avatar
I have a gauge for that
You should be able to spin the power steering pump pulley easily by hand, if you cant, you have a bad pump...
Old Nov 10, 2011 | 10:34 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Did you have the lines off when you did the swap??? The ABS code might also be a good indication of whats going on... Do have a scan tool that can read ABS codes???
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
GMCtrk
18
Oct 6, 2015 03:48 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
