-   GMT 800 & Older GM General Discussion (https://www.performancetrucks.net/forums/gmt-800-older-gm-general-discussion-130/)
-   -   hydroboost on 2wd with rack & pinion steering (https://www.performancetrucks.net/forums/gmt-800-older-gm-general-discussion-130/hydroboost-2wd-rack-pinion-steering-525005/)
Chevy_King1500 Dec 25, 2013 04:05 PM
i recently bought a hydroboost setup from a member on here and will be installing it soon, i have seen all the right ups for the guys with gear box steering, but cant find anything on the rack and pinion.
it may be a simple swap, to be honest i have not actually looked around on my truck to see how everything would hook up, figured i would ask on here first
Thanks
GMCtrk Dec 25, 2013 04:09 PM
I didn't do anything differently on mine. Very straightforward install.
Chevy_King1500 Dec 25, 2013 06:42 PM
alright, ill look at it tomorrow i was just guessing it was different on the 4wd trucks
Chevy_King1500 Dec 26, 2013 08:58 PM
started on the swap tonight and everything was going good, I removed the vacuum booster and got the hydroboost bolted in and then I started on the high pressure line. So I jacked the truck up and unbolted the line coming out of the pump and then it went downhill from there.
when trying to remove the line from the gear box it's freaking stuck! I spent nearly 2 hours tonight before giving up, my 11/16" line wrench was not going on the the fitting so I tried 18mm then I ground a slot in an 18mm box end so I could use it like a line wrench, that still slipped.
so I'm going to try again tomorrow after work. I plan on just pulling off the gear box and rack and pinion
Chevy_King1500 Dec 26, 2013 09:01 PM
1 Attachment(s)
Attachment 107435
Red_Beard Dec 29, 2013 11:49 PM
any updates on your progress?
Chevy_King1500 Dec 30, 2013 06:14 AM
yup,
https://www.performancetrucks.net/fo...orking-525075/
