How big is the gas Tank in your 2500HD
How big is the gas tank in your 2500HD? I thought I read in a dealer broceher that the tank was supposed to be like 32 gallons. I can't find it right now.
Curious because when we fill up it seems like we only have 26 gallon tank like in my 00 silverado. Fill up rate is the same... same amount put in and the same amount of MPG Vs. my 00 c1500
Any body have any info on this???
Hmm does not say but the guy at the dealer said it was built with a 26 Gallon tank. I thought they only came with a 32. says he puts 24 Gallons in at fill up...
Intresting. were did you get that info? when I asked the guy at the dealer he said it could have been built either way but he would need my vind to see what the factory installed. I asked if it was possible to have gotten it with a 32 gallon take and he said he was not sure.
the length of the larger tank doesn't fit with the short box wheel base. gm and ford does this on all of there trucks. dodge may also i just don't have any experience with them. the aftermarket tanks that are larger go higher up(closer to the bed and cab floor) and hang down about and inch below the frame.
Thats funnny because some one that works with my dad got a 4x4 version of the same basic truck except ours is GMC and theres is a Chevy and his has the larger tank as he has to more gas in his. Maybe 4x4 vs 2x4 option???
From: as far away from Koonerville as humanly possible
Unless there is some new option that I don't know about, (not likely). the info above is correct.
Shortbed = 26
Longbed = 34
It's been that way since 1988, maybe longer.
Shortbed = 26
Longbed = 34
