Is a hot wire kit necessary for one walbro 450 02 silverado
Old 11-19-2017, 10:34 AM
Shtbox's Avatar
Default Is a hot wire kit necessary for one walbro 450 02 silverado
My truck was running for 2 days great then out of no where it cut off on me.let it sit for a little bit then started back up then died again in like 5 seconds.Fuel pump cutting in and out
Old 11-19-2017, 10:44 AM
I have a gauge for that
Atomic's Avatar
Yes. The 450 draws way more power than a stock pump and will melt stock wiring. You may also have a hose failure if you didnt use the right hose.
Old 11-19-2017, 12:31 PM
03sierraslt's Avatar
Like Richard said, a 450 draws too many amps for stock wiring. Esp for an 2002, in 04 they started upgrading the bulkhead connector but the wiring still is too small.
Old 11-20-2017, 12:02 AM
Shtbox's Avatar
Ok well I guess I gotta buy one what happen was the install kit I got came with a connector but the rubber swole up and pushed it apart I said to help with it and solder the wires together.Any recommendations??
thats the hose i used i hope it was right the guy said it was fuel line,i said is it submergable I lost the guy when i brung that up so i was like give me the damn hose
Old 11-20-2017, 12:03 AM
Shtbox's Avatar
ok thanks for the reply where would be a good place to buy
Old 11-20-2017, 12:21 AM
Fullpower's Avatar
You'll likely be right back under there soon, give you a chance to fetch up a couple good fuel injection hose clamps, and a foot of SUBMERSIBLE FUEL Hose... Keep that, and your tool box in the truck with you.
Old 11-20-2017, 07:42 AM
Atomic's Avatar
Thats a transmission fluid rated hose, not a submersible fuel one. You need something in accordance with SAE 30R10 spec, like this:
Amazon Amazon
Old 11-20-2017, 11:43 AM
Shtbox's Avatar
dammit ok thanks for the heads up
Old 11-20-2017, 11:46 AM
Shtbox's Avatar
Thats a transmission fluid rated hose, not a submersible fuel one. You need something in accordance with SAE 30R10 spec, like this: https://www.amazon.com/Gates-27097-S.../dp/B001R5XX56
thanks for the link I need to do that today this is my daily,hope I can find some local.How about the soft line coming off of the fuel rail on any gm car the soft rubber hose before it turns into a hard line I work at a salvage yard maybe I can find some laying around.and normal hose clamps are no good?
Old 11-20-2017, 12:00 PM
11 Second Club
MrHorsepowerLSx's Avatar
Hose HAS to be submersible!! If you use “ soft hose” as mentioned the outer shell of the rubber will deteriorate quick as hell inside the fuel tank. Those types of hoses have a special inner lining and a plain rubber on the outside. It can withstand normal elements but it wouldn’t survive inside your tank. The gates hose that Atomic mention is a cheap $20 piece of mind and it comes in a foot per package. Most parts stores don’t carry it and needs to be ordered online. I have been using that hose for years as my Go to hose for doing fuel systems. Never had any issues with it. And did you zip tie the hose to the barb ?! It’s better practice to use fuel injection hose clamps as they are smooth in construction as opposed to standard worm gear clamps which tend to cut the hose and not seal in a “perfect” circle as the fuel injection hose clamps
rocknZ71 (11-27-2017)
