HD/ Denali Cluster
Old Sep 7, 2011 | 10:55 PM
Slammed96's Avatar
Default HD/ Denali Cluster
Not sure where else to post this, so it will be posted here. My question is, if I can find a decently priced HD or Denali gauge cluster with the trans temp gauge, will the trans temp gauge work in my truck without modification? I have heard that it will work on some, but would like to be sure before I buy one.
Old Sep 8, 2011 | 06:41 AM
Coban's Avatar
Yes, the temp gauge will work.
The mileage will read according to what is in the cluster, not the mileage for your truck. You can get this re-programmed.
Old Sep 8, 2011 | 02:03 PM
Slammed96's Avatar
Thanks. I knew the milage would be different, just wasnt for sure on the temp gauge.
Old Oct 18, 2011 | 04:50 PM
Silverado777's Avatar
There is also a possibility that your cluster is already programmed for a trans temp gauge. If you pull it apart and there is a light bulb where the tranny temp gauge goes then you will just need to add a stepper motor, needle and a seven gauge overlay. No bulb=no tranny temp gauge.
Old Oct 18, 2011 | 05:42 PM
Yes it will work. I put a Cadillac Platinum cluster in my GMC(had it programmed for mileage and hour meter) and it works and looks great. I got mine off EvilBay.
Old Oct 29, 2011 | 12:08 AM
Ydtrack's Avatar
I tried the cluster swap, but was unable to get it re-programmed. I found a guy in Ebay who would add the tranny temp gauge to my original cluster, as well as converting it to the white face SS gauges.
03sierraslt
14
Oct 9, 2015 05:53 AM
GMCtrk
18
Oct 6, 2015 03:48 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
