Hard Steering, please help
Old Feb 20, 2013 | 04:56 PM
offroadrider12's Avatar
Default Hard Steering, please help
2003 GMC Sierra 1500 2wd 5.3 RCSB 180,000 miles
The power steering pump isn't making any odd noises, still can hear the pressure relief valve open when at full lock. Changed PS fluid, was clean, made no difference. No visible leaks.
The steering tension isn't consistent. Doesn't seem very speed dependent, maybe a little easier at speed, not much. After making a turn, turning the wheel in the opposite direction seems very difficult.
How do I diagnose what needs replacement? PS pump, rack & pinion or other part?
Old Feb 22, 2013 | 12:07 AM
Suburbazine's Avatar
Probably a bad steering angle sensor. I forget what the doohickey is actually called, but it controls the boost pressure the power steering pump is allowed to make.
Old Feb 24, 2013 | 02:56 AM
So you think it's the steering wheel position sensor?
I thought I had it all figured out when I found a TSB about changing the steering gearbox for the issues im having...then I realized 2wds don't have a steering gearbox...unless im missing something.
I now see the rack & pinion is weeping slightly, not dripping oil, but just a little wet.
I'm lost.
Old Feb 24, 2013 | 06:41 AM
MonkeySkull's Avatar
Registered User
There will be a solenoid on that box I believe. It watches your VSS and regulates how much assist you receive. I would check the solenoid, you'd need to find a diagram to determine if it's a normally open or normally closed solenoid first, or a stepper motor.
Old Feb 24, 2013 | 07:25 AM
chevymec's Avatar
Tire pressures all good in front? Sounds like the rack is going out.
Old Feb 24, 2013 | 10:47 AM
Where is the solenoid? I thought I had a steering gearbox at first, but I don't think the 2wds do? I'm not seeing one on my 03.
SloSVO
Nov 22, 2020 07:34 PM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
dsbodley
Nov 14, 2015 09:46 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
Blklgt
Sep 28, 2015 03:21 PM
