got a leaky ss
Old Sep 23, 2012 | 06:14 PM
sam5300's Avatar
Default got a leaky ss
My Silverado ss has been leaking coolant very slowly for a month or so now, but now its getting worse now. From my investigation it looks like its coming from the water pump itself, not the gasket. So what's the preferred Water pump around here? Factory GM pump?
Old Sep 23, 2012 | 06:36 PM
03sierraslt's Avatar
I would stick with a factory pump, allot of the aftermarket pumps are junk.
Old Sep 23, 2012 | 06:45 PM
sam5300's Avatar
Alright I'll have to go get a quote on one from the stealership
Old Sep 23, 2012 | 07:01 PM
You can find them online too.
Old Sep 23, 2012 | 07:31 PM
WhiteChevy3's Avatar
Try flea-bay for an oem pump and weld the pulley.
Old Sep 23, 2012 | 07:32 PM
La SS's Avatar
This.
Old Sep 23, 2012 | 07:33 PM
TIM Z's Avatar
11 sec. Truck Mod
X2 !
Also Pat just installed a new pump, and informed me about better gaskets to use than the factory ones, chime in Pat if you check this, I forget what you said, maybe felpro or something?
Old Sep 23, 2012 | 08:24 PM
sam5300's Avatar
Old Sep 23, 2012 | 08:25 PM
sam5300's Avatar
I'll check online for better deals on an OEM one. Maybe on gaskets too.
Old Sep 23, 2012 | 08:57 PM
1FastBrick's Avatar
Custm2500's Rude Friend
The problem with the original gaskets is that the orange rubber would pull away from the metal. Also the heat cycles would allow the bolts to back off. I have used the new OEM gasket's with Black rubber With the OEM pump and torqued to 20 FT Lb instead of the 18 and have had no issues.
Some one does make a paper style gasket if you feel better about using that style. I found them by looking up a 97-98 corvette which I believe used a paper gasket from the factory.
FEL-PRO Part # 35636
VICTOR REINZ Part # K31627
Attached Thumbnails got a leaky ss-water-pump-1st-design.jpg   got a leaky ss-water-pump-2nd-design.jpg
