GMT400 vs GMT 800 Drag Truck
Old 04-13-2018, 09:41 PM
DrkSide11's Avatar
Default GMT400 vs GMT 800 Drag Truck
Looking for some opinions as I am having a hard time making a decision. Have an itch to build a performance oriented truck since going to the races with a friend last year but can't make up my mind between keeping and building the 98 RCSB I have or moving up to a newer 99-06 model.
OBS Pros -
Already have the truck
A little lighter (I believe) than the later generation
OBS Cons -
Engine and trans swap
Limited suspension options
NBS Pros -
Keep engine in it
More suspension options
Less wiring (I hate wiring)
NBS Cons -
Still have to swap trans
Plans are to start with a single turbo setup and grow from there. 500ish HP to start and then I know I'll get the bug for more. Anyone have any insights?
Old 04-13-2018, 11:56 PM
arthursc2's Avatar
Received 1,433 Likes on 1,061 Posts
NBS. Better frames and better looking trucks.
Plus more aerodynamic for when you start hitting 150mph
Old 04-19-2018, 11:39 AM
11 Second Club
MrHorsepowerLSx's Avatar
Go for the OBS, they are indeed lighter then the GM800 platform. Also the GM800 has more wiring then an OBS, to give a quick example, there are 8x coils that require there own power supply as opposed to a single distributor
Old 04-19-2018, 12:19 PM
arthursc2's Avatar
If he is LS swapping it (which he should), what difference does the wiring make?
he did mention the con of an OBS was the requirement of swapping the engine. So he is planning that anyway.
NBS all the way.
Old 04-20-2018, 09:18 AM
10 Second Club
OBS, lighter. Shouldn't be too complicated for wiring... run a stand alone. (Either reworked factory harness or aftermarket)
Just my $0.02
Old 04-20-2018, 09:29 AM
someotherguy's Avatar
GMT400's look better, too. Roast me. I don't care.
Richard
Old 04-20-2018, 01:24 PM
arthursc2's Avatar
Richard
no roasting needed, we all know someone that needs to wear a helmet 24/7. You just happen to be that someone
Old 04-20-2018, 01:42 PM
You're right! What the hell am I doing with a pair of 06's in my driveway..
Richard
Old 04-20-2018, 02:06 PM
arthursc2's Avatar
Hahaha. Perfect
Turbo09
03-13-2017 05:31 AM
thunder550
02-24-2013 07:39 PM
01SilvyZ71
02-16-2012 08:35 AM
ZZebes
03-15-2009 10:35 PM
Quick Reply: GMT400 vs GMT 800 Drag Truck
