Gauge Mounting
Old Jul 27, 2006 | 11:04 AM
Dub Silverado's Avatar
Default Gauge Mounting
Where are you guys mounting your gauges? I need to mount two gauges and thought about two things. Either the Socal diesel overhead billet mount, or having someone fiberglass my console where the two cubby holes are and putting them there. I was going to just do the socal diesel way out of convienience but they are out of the shop till aug 1 and I want to order something now. Im impatient.....
PS not interested in pillar gauges.
Old Jul 27, 2006 | 11:35 AM
silver-mod-o's Avatar
Hunt&Fisherator
I'd wait for the SoCal mount.. it'd be worth it IMO... those things go in clean as hell.
Old Jul 27, 2006 | 12:15 PM
02BlueStepside's Avatar
Mine are in the A pillar and the overhead console, socal diesel mount.
Old Jul 27, 2006 | 12:27 PM
Yea im going to get them to express ship it to me on tuesday when tehy get back in the office.
Old Jul 28, 2006 | 01:24 AM
02 blue, where those gauges hard to wire up? my gauge is ghetto mounted, through the firewall out the fuse center and double sided adhesive in the corner. works well and its easy to mess with. hopefully only a temporary location but im cool with bein a little ugly. i also have a switch double taped to the side of the dash.
Old Jul 28, 2006 | 01:04 PM
Which gauges? The interceptor gauges (pictured) plug into the dianostic port and have 1 power wire to them, so yes they were very easy. The others in the truck, boost, fuel pressure, and air/fuel were a little more involved, but still not to bad.
Old Jul 29, 2006 | 12:38 AM
they just plugged into your diagnostic port under the dash? where did you find this set up? i was looking at so cal and liked they over head gauges like you have pictured for trans temp and AFR. im guess i would have to custom wire those because they are afternarket sensors? follow the a-pillar, through the cieling mat and into the overhead thing?
Old Jul 29, 2006 | 07:41 AM
Depending on the particular gauge, and if its electric on mechanical, things will vary a little, but I used this guide to help me out.
https://www.performancetrucks.net/fo...d.php?t=349018
I got the interceptor gauges that are in the overhead from here
http://aeroforcetech.com/
I would go with one of these gauges over a tranny temp gauge since these will read tranny temp among many other things. You could also just upgrade to a Denali, Escalade, or HD gauge cluster and get the tranny temp gauge.
Old Jul 29, 2006 | 08:14 AM
thanks man, those are pretty sweet maybe when i need some gauges again ill order some up. i like the whole set up
simman22
Jan 21, 2017 10:27 PM
dantheman1540
Feb 24, 2016 09:56 PM
FlyingLow
Nov 24, 2015 10:05 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
thewrx
Oct 6, 2015 10:59 AM
