Fuel Pressure Regulator
Anyone have any Ideas on where and what fuel pressure regulator to install on a 05 Returnless fuel system. Ive done the install on the Bosch 040 intank, and now that I have eleminated the intank filter and fuel regulator I need to find another place to put a regulator.
try running it using the same one that way I'll know for sure if it's my fuel pump. I know it's run with it on. If your not going to use them how many miles are on your fuel filter and regulator.
less than 60k. Only thing is I dont know how I am going to get the tubing and fittings needed to do the install
all you need to do is put the pump in run a 3/8 line into the fuel filter and then another one out from the fuel filter to the top out of the pump. only fitting you need is 12mm AN fitting that will hook up to the top of the fuel pump so you can hook up the hose. Then on your fuel filter/regulator connections just cut the hoses off but don't cut through fitting that plugs into it so you can reuse them.
I got my fitting/hose from a hydraulic parts store.They even offered to fit it together from me. cutting it to exact length and use some type of connections on the hoses to avoid using clamps. But you can do all that.
