front left axle removel
Hello i am having a hard time removing the left axle im trying to get the seal replace i tried the slide hammer and hitting it with a 2 pound hammer.
I NEED SUGGESTIONS
I HEARD A GUY SAY PUT A 12 INCH SCREW DRIVER ON ONE SIDE AND HIT THE OPPOSITE SIDE. I HAVN'T TRIED THIS YET
I NEED SUGGESTIONS
I assume you took the 6 bolts out that hold the axle to the stub then the 1 axle nut on the front.
You may have to unbolt the shock to drop the axle out of the way.
The stub piece I push back in with my hands then I stick a pry bar going from left to right and smack the end of the pry bar with a hammer and the stub pops right out.
Pry bar between the flange and the diff, prybar against the seal if that makes sense and give it a nice sharp wack with a hammer.
Chunk of 2x4 or similar against the flange about where the bolts go thru and angled down towards the ground towards passenger side on opposite end,again nice hard wack with a hammer. This really only works when the truck is on a lift.
Hit the center of the flange into the diff once or twice then try prying/hitting it out again.
I use my little mini sledge.
Knock on wood but doing this ive always been able to get them out.
Worse case and ive seen it a few times now is diff has to be pulled and taken to a machine shop or someone else with a press.
x
