Originally Posted by styleandspeed
I had mine replaced by the dealer already, and it still did it driving on the way home. If they can't fix it the next time, then I am going to get a big tube of silicone and glue the bastard shut. I never open it anyway.
Aaron |
pics no worky :cry:
Originally Posted by 02sierraz71_5.3
pics no worky :cry:
https://ls1tech.com/forums/member.php?u=11859 |
I refuse to let this post die!!!! I must have pics!
gee whiz i have a life you know.
http://img.photobucket.com/albums/v1...i/MVC-831S.jpg http://img.photobucket.com/albums/v1...i/MVC-830S.jpg i drilled a small hole in the bracket that is mounted to the rear doors. then into the door itself and inserted a screw threw them.1/2 a turn was all i needed. |
Very nice. I'll have to give it a go.
Thanks. |
this is the third truck i have done it on and it has worked perfect.
How hard is it to separate the latch assembly from the glass? id think a little rubber washer between the "button" on the outside and the glass would have it pull tighter?
there is just a slotted arm that holds it in. pop it out and drill the little hole. leave the button on the window alone.
thanks for the pics denali, have you tried self-tapping screws I wonder if those would be a good way to go?
