drilled and sloted rotors worth it?
so i need to do my brakes and money is tight, but i could swing some drilled and slotted rotors, with stock calipers. worth it? if so whats a good brand?
They look nice... I wouldnt get ones that are actually drilled, more often then not they will crack.
they say slotted helps cool them off and clean the pads. If you can get slotted and dimpled for slightly more i would do it but dont break the bank for them. you also want to look at coating, are you worried about them getting rusted? |
I would only do it if you go to a plus size rotor with a caliper relocation bracket. Should give you a little better stopping. If you're going with stock size I'd just go with OEM...they last forever. 163,000 miles on my truck and I'm still on the original rotors and only my second set of pads.
:stupid: like thunder said get the drilled and slotted rotors but get the plus size ones make a bigger differance then the stock size drilled and slotted
and if thats out of your price range then just get a stock set with a good set of pads. if you really wanted to you could do these:devil: http://i187.photobucket.com/albums/x...console008.jpg |
Originally Posted by twolow02fransen
(Post 4031535)
can you use stock calipers with plus size rotors?
Originally Posted by colekill
(Post 4031833)
Originally Posted by 53RUSSELL
(Post 4031816)
Where did you get the relocation bracks for those calipers??
Slotted and cross drilled rotors are waaaayyyyy worth the coin!!! It will eliminate the warpage that the OEM rotors are notorious for.
I have a set on my truck that i got off of ebay for like180-200 shipped for all 4. Worth the money. I have cross drilled rotors on my truck.
