Door compatibility with a 02 silverado rcsb
Registered User
I'm going to swap out the doors on my truck they need to much work to be worth saving. What models and years are compatible obviously 99-02 silverado RCSB. I believe the crew cab and extended front doors are the same. aren't Tahoe doors the same as Well? What about the 2500 series?
Yeah, any 99-06 Silverado or Sierra will work, regardless if it's a 1500, 2500, or 3500. Plus the doors from a 00-06 Tahoe/Suburban, Yukon, Denali, or a 02-06 Escalade, and Avalanche will also work. Just be aware that a door on a Escalade or Avalanche with the plastic cladding may need some minor body work on it after you get the body cladding off the door. So in a nutshell, I'd honestly just avoid those unless you get a killer deal on one.
