Door compatibility with a 02 silverado rcsb
Old 10-23-2017, 08:15 AM
Registered User
ddevitte1's Avatar
Default Door compatibility with a 02 silverado rcsb
I'm going to swap out the doors on my truck they need to much work to be worth saving. What models and years are compatible obviously 99-02 silverado RCSB. I believe the crew cab and extended front doors are the same. aren't Tahoe doors the same as Well? What about the 2500 series?
Old 10-23-2017, 10:12 AM
FFDP's Avatar
Tahoe/suburban front doors should be the same. The 2500/3500 run the same cab sizes too so the doors work.
Old 10-23-2017, 10:19 AM
Registered User
ddevitte1's Avatar
Thanks.
Old 10-23-2017, 12:54 PM
ScottyBoy's Avatar
Yeah, any 99-06 Silverado or Sierra will work, regardless if it's a 1500, 2500, or 3500. Plus the doors from a 00-06 Tahoe/Suburban, Yukon, Denali, or a 02-06 Escalade, and Avalanche will also work. Just be aware that a door on a Escalade or Avalanche with the plastic cladding may need some minor body work on it after you get the body cladding off the door. So in a nutshell, I'd honestly just avoid those unless you get a killer deal on one.
Old 10-24-2017, 04:19 PM
Registered User
ddevitte1's Avatar
Thanks
