In desperate need of help. Misfire issue.
I really appreciate all the help from everyone. I don't post much, but I have been lurking on this site for a long time. Lots of knowledge and great advice to be had here.
Well, still no luck. I tried some new plug wires to no avail. I took the intake manifold and valley cover off to see if I could inspect the cam for worn lobes. The cam looked in great shape. Its as if its mechanically in time but electronically out of time. I'm going to pull the starter today and see if i can inspect the reluctor wheel on the crank. Maybe it slipped? If I don't see anything there I may just throw a new crank sensor in it and see what happens.
Nope I didn’t. I should have read the directions completely before I started. I replaced the oil pan gasket because it was leaking pretty bad. I checked the reluctor wheel while I had the pan off. It looked good and hadn’t slipped. I replaced the crank position sensor also and was able to complete the relearn procedure. Still misses.
