Connecting regulator to returnless rail?
I was going to try a walbro 400lph on my factory returnless system but I've been told it will overpower the factory regulator. Next step is to convert to return style and add a external FPR. But I'm not very positive to where the regulator connects to after my returnless rail. I'm not trying to swap out my rails.
If you are gonna go return and use the factory rails then you will have to dead head them.
From tank to regulator, regulator to rails using a standard EFI fitting, and return ran normal.
Use a regulator with two inlets and one return
Makes sense, but I didn't think doing it that way was much good. I'll have to research a little more
