Benifits from a low temp thermostat?
Old Nov 28, 2011 | 10:01 AM
Alpinestar's Avatar
Originally Posted by wld1985
So do they make an 180 for the trucks? Or is an order thing? I've always hated Dex-cool and switch over to the green stuff..
I'm running a 180* thermostat that I got from lingenfelter.
There is a big debate on whether a 160* thermo is to cold for the gen III-up engines so you might want to do a couple of searches before you decide on one. Basically what I got from all the debating & research was that the LS engine likes to run hotter than the older generation motors. The engine also needs to get up to a certain temperature to burn off any condensation that is in the oil which the 160* may not allow in real cold climates. I think it was zippy who did a lot of testing on where a naturally aspirated LS engine makes it's peak power and it was between 170*-180* if I remember right. Given that your coolant temp will be a little warmer than your thermostat, I think that in most cases a 160* will be best in the summer and the 180* for the winter. My truck is my DD so I just keep the 180* in year around so I don't have to mess with the tune/changing the thermostat and fluids. I am in no way an expert on this subject this is just my assumption based upon what I have read.
Old Nov 28, 2011 | 07:11 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by lady3bglover
Billy, I don't know why you haven't already. I've had the 160* on the 5.3 and now the 6.0. I've been running low to mid 170's consistently, but the real test will be in the summer. The swap is simple.
Last year upgraded to the Genesis 34" all aluminum radiator, and just this week to the 4000cfm Dorale e-fans. I threw some fresh 50/50 Dex-Cool just tonight, and I'm still at 176 at the high point, low at 168.
LOL, because that t-stat and dexcool is expensive I've been holding off until I build the LQ9...but, who knows when that will happen
Old Nov 29, 2011 | 08:21 AM
lady3bglover's Avatar
Hope this helps
JordanH
Oct 3, 2015 03:59 PM
LSX-81-SIERRA
Oct 2, 2015 07:05 AM
carid
Oct 1, 2015 09:22 AM
redbird555
Sep 30, 2015 09:28 AM
Rockrz
Sep 29, 2015 09:07 AM
