autozone torqflo fan clutch any good?
Old Jul 17, 2013 | 09:57 PM
  #21
Mikey 97Z M6's Avatar
11 Second Club
I just replaced a waterpump and decided I might as well replace the fan clutch also. I got a Hayden and I wish I would have left my stock one on there. This pos is loud all the damn time. Sounds like a fricken jet airplane taking off from stop lights. I cant stand it and am looking into the eFan setup. This is rediculous. It wil even do this in the morning when I first start it and its cool out (less than 60 degrees). My stock one has NEVER been this loud, even in 100 degree heat with the A/C on.
Mike
Old Jul 17, 2013 | 11:15 PM
  #22
Jaxon2580's Avatar
I had a Napa HD clutch put on and so far so good, not loud at all really I don't notice it ever, my stock one would make the loud fan noise before it warmed up which I though was normal and this one doesn't even do that, very happy with it I idled it for 30 minutes never once twitched on the heat gauge, in 110° Texas everyday weather
Old Jul 18, 2013 | 09:27 PM
  #23
Jaxon2580's Avatar
Should I replace the cap on the coolant system? I don't want it to hold excess pressure and cause another leak
Old Jul 18, 2013 | 09:49 PM
  #24
Suburbazine's Avatar
A cap is a cheap replacement- don't worry about it, just replace it.
Generally when they go bad they don't hold excess pressure; they don't hold any pressure at all which causes the coolant to boil off and leave the cooling system for good. And boiling off in the heads is bad juju.
I think the GMT-800 cooling systems are 13-15PSI.
Old Jul 19, 2013 | 01:52 PM
  #25
Jaxon2580's Avatar
15 psi, I picked up a cheap 7 dollar cap from auto zone, its not OEM and doesn't have the OEM cap instructions but it says its for 15psi and that's what my stock cap says and the look exactly the same so I replaced it, unless I should've used the 20 dollar dorman one instead?
Old Jul 19, 2013 | 10:36 PM
  #26
The one you got is fine. As long as the pressure rating was between 13-15PSI and it screws down normally you're good.
The only real issue with the cheaper ones is that the seals will fail/rot sooner.
Old Jul 20, 2013 | 04:07 AM
  #27
Jaxon2580's Avatar
Well replacing it isn't a big deal, and its the motorrad brand cap
ferrellrooster
Mar 6, 2025 03:22 PM
DrX
Aug 19, 2015 04:45 PM
Ketis
Jul 23, 2015 12:37 PM
rojeho
Jul 12, 2015 06:10 PM
