- - alternator stops working randomly
(https://www.performancetrucks.net/forums/gmt-800-older-gm-general-discussion-130/alternator-stops-working-randomly-369734/)
quanrud126
10-08-2014 11:41 AM
Originally Posted by SimpleManLance
(Post 3392407)
lately my alternator just stops working, i will be driving along and my volts will be at like 10-12 volts. it first started when i was towing my buddies boat and i backed it into the water then pulled it out. i thought maybe it was shorting it out or something. but then it started happening just randomly. i took my alternator back to napa where i bought it and had them test it. they said it was fine and putting out 15 volts. so i cleaned all my terminals and made sure everything has a good connection. it worked well for a couple of days but now it is screwing up again. today i was looking at houses and i noticed my volts were gone. so i disconnected the plug and the ground like i have been doing to fix the problem. then ten minuted later when i was going down the e-way it screwed up again i have a 145 amp alternator from napa and a red top battery, both are under a year old and have very little use because i rarely drive the truck. anyone have any ideas on what it might be, im clueless and its really starting to piss me off because i dont want to be left stranded anywhere. thanks
Did you ever track down what the problem was? I am literally having the same problem. I hauled my cousins boat, put the boat in the water. Pulled out and now I have been having the same issues for the last week now.
