Ls2 or lq9 OBS
Old 09-09-2016, 11:57 PM
Registered User
Nawaf's Avatar
Default Ls2 or lq9 OBS
Hi guys, I'm new in this world but I've read so much in this forum it teaches me alot of things, thank you ppl
Guys I really want some power my goal is to hit 450rwhp N/A and the drivability is so important to me.
I heard a lot of guys said that I should go with lq9/lq4 it's a common swap, likes the power and strong as hell
On the other hands, they told me ls2 engine is great engine, they showed me dyno numbers, and I think there will be zero issues for 450rwhp
I know it's a Truck but a 2wd truck, 1500, 5 speed manual,3.73 limited slip rear end and I don't like to tow. I want a street monster
So my question is
Should I go with ls2 or lq9 ?
What would be the easier way to 450rwhp with less mods ?
And what would be the easier swap for me ?
What do I need to swap it ?
Thank you guys
Old 09-10-2016, 10:42 AM
FFDP's Avatar
I suppose either would be an alright choice. Around here the LS2 will be like triple the cost of an LQ9 though from what I remember seeing.
Very possible to build the LQ9 for more power and still be cheaper than an LS2 pull out. Bigger camshaft, different cylinder heads or good head work, TBSS/NNBS intake manifold, headers and a tune. The tune is going to be the biggest thing for driveability.
Old 09-10-2016, 01:19 PM
11 Second Club
MrHorsepowerLSx's Avatar
Just find and LQ9 short block and invest the money on the cam/ top end. Way cheaper then getting an LS2. Also remember ls2/lq9 share the same rotating assembly.
Old 09-11-2016, 06:45 AM
Registered User
Nawaf's Avatar
So do you think my truck gonna hit 450rwhp with lq9 and this combination ?
Because I haven't seen anyone did 450rwhp out of lq9 truck with this simple work, but I've seen a lot of TBSS hit that 450rwhp with simple mods
What do you think ?
Old 09-11-2016, 06:47 AM
Registered User
Nawaf's Avatar
So what do you think ?
Old 09-11-2016, 10:18 AM
FFDP's Avatar
Over 400 sounds totally possible, don't be so dead set on 450.
Raise the compression ratio to match the LS2, add a decent sized camshaft with a good flowing NNBS intake manifold, pair that to a decent set of headers with a tune and you have one pretty good combo for power.
The LS2 gets it's extra power from a higher compression ratio and different cylinder heads/cam.
Old 09-11-2016, 06:41 PM
11 Second Club
I have an iron LS2 in my truck (LQ9 bottom end/block and a complete TBSS top end) my heads are stock besides valve spring upgrade, and a baby cam and my combo is just about maxed out with the tune/injectors/head flow etc and I'm a 401rqhp/410rwtq. To get to your power goal, you would need a healthy cam/ ported heads bigger injectors and a small bump in compression would help get you close to that power goal, but the stock stuff starts to show its head around the 390-410 rwhp mark N/A before you need to switch some things around
Old 02-15-2021, 07:23 PM
GREENSIERRA's Avatar
I am no tuning expert but it sounds like the throttle cracker and follower need some work.
I run a large cam with a tight converter and have no drivability issues
dry_kill
03-30-2010 07:15 PM
clemsondave
01-14-2009 10:03 AM
vVandals909
02-20-2006 01:37 PM
2002C5COUPE
13
06-24-2005 12:07 AM
Quick Reply: Ls2 or lq9 OBS
