ABS and BRAKE light coming on all the time. have searched. Need help ASAP
Old Aug 2, 2012 | 02:58 PM
Ferocity02's Avatar
MANY things can cause this. For one, could be a bad ABS module as stated. Bad speed sensor will also do this. Does the speedo bounce around at all while driving? Bad wheel speed sensor. If it had a gear swap and wasn't retuned it can cause this. I don't think you will find any codes for the ABS/BRAKE lights.
Old Aug 2, 2012 | 03:09 PM
mvrk10256's Avatar
The speedo does not bounce around. I dont think it has had a gear swap but I could get the back end in the air and measure.
Old Aug 2, 2012 | 03:35 PM
Robert91RS's Avatar
Find a code reader that can pull ABS codes. If the lights on, there is a code.
If the code says faulty relay its your module, otherwise it will complain about a particular wheel or brake sensor.
Old Aug 2, 2012 | 03:36 PM
mvrk10256's Avatar
mmight give dealer a call then.
Called dealer. they want $50 to pull a code. **** that. I can check all of the wheel sensors myself.
Old Aug 2, 2012 | 04:48 PM
Robert91RS's Avatar
Have you checked Autozone and Oreillys? Some of the scanners they use and loan out can pull abs codes.
What if all the wheel speed sensors test good, so you throw a EBCM only to find out it was a stuck valve in the BPMV or a bad connector going to one of the speed sensors.
Pull the codes sir.
Old Aug 2, 2012 | 04:52 PM
mvrk10256's Avatar
Pull the codes sir.
I was going to stop by Oriellys tonight after work. but my elm scan tool is supposed to be pretty good. Worth a shot though.
Old Aug 2, 2012 | 05:01 PM
Robert91RS's Avatar
Let us know how it goes.
Old Aug 2, 2012 | 05:02 PM
mvrk10256's Avatar
Thanks. I will get codes pulled, check everything this weekend, if I still dont have an obvious candidate I will probably swallow the $50 and let the dealer pull the codes for me.
Old Aug 2, 2012 | 07:52 PM
TXSZ66AVLANCHE's Avatar
You need to use a scanner that can pull abs codes.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
atxlt
Jul 20, 2015 11:06 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
1320Chicken
Jul 14, 2015 10:58 PM
hackrst
Jul 11, 2015 11:17 AM
