5.3 swap to 6.0
You should include far more information than that, we have no idea what this is in or what else is done to it.
Is it stock?
What year vehicle?
And codes?
Do you have a scan tool?
Did you tune it for the swap? Lots a parameters need to be changes when doing a motor swap like this.
Vacuum leaks?
Is it stock?
What year vehicle?
And codes?
Vacuum leaks?
Thanks for the reply. I am very new to this, as for the missing info- 02 suburban 1500 4x4 , air filter and cat back exhaust. Ordered new pcm, still waiting
runs steady @1000rpm or higher but once I let off the gas it drops below 500 and dies.
rjid (03-03-2017)
the code are
P0443 Purge Control Valve Circuit Malfunction
P0300 is random misfires
misfires could be plugs, wires, coils, coil packs plugged in wrong, fuel pressure or even the pcm has the wrong flash? my sons pcm was flashed for DBW and his setup is DBC it would start and idle fine real smooth but if we rev'd the engine it would bust up and misfire had to send it back and get it reflashed for DBC
the purge valve lines get brittle might have a leak or somethings not connected?
